Can you add a way to disable ad block for all sites and enable it only for a particular site in the next firmware update?
Would be a great thing, the way you explained to me is not functional, in the sense that there are too many steps to do something that should be simple to do. Unfortunately, nowadays blocking ads means making websites work badly, or some not working at all. So it would be too difficult to do the way you told me for every site where I would like to block ads.
