Home Forums Troubleshooting CF-WR619AC – how slow is it?
  • #7175
    ccsmith
    My new CF-WR619AC replaced a (dubiously secure) TP-Link router. I have fiber to the office, and would routinely get 800 Mbps up and down. With the new replacement router I get about 1/4 that. Why? It has the same “Gigabit” ethernet ports – or is that just marketing hype?
    #7176
    ccsmith
    Slightly off topic – by preference I have 5 GHz enabled and 2.4 GHz disabled. The blue light on the front panel for 2.4 GHz (to the right of the 5 GHz light) is on and 5 GHz is off. Mislabeled? Can’t find a Chinese router made by people who read English?
    #7184
    Ethernet ports are gigabit, but you won’t get gigabit on WiFi. For the CF-WR619AC, enabling “Software flow offloading” on the Network Settings page will significantly improve WiFi speed (to somewhere near 500 Mbps). You can also connect your TL-Link as an access point to add more WiFi capacity.
    And you’re right, the WiFi LEDs on the box are mislabeled. I’d suggest that you keep both 2.4GHz and 5GHz but use the same SSID for both bands. You’ll have more WiFi bandwidth and your devices will select which band to connect to. Plus the longer range for the 2.4 GHz band.
