Your best bet to determine you max internet speed is to connect a PC that has ethernet directly to your cable modem or optical network tranceiver (ONT) and run a speed test from the computer. To get the most accurate results reboot the computer and then be sure the speed tester is the only program running. If using a browser based speed checker be sure there is only a single tab open.
Best to try a few different speed checkers.
