I wanna block a specifi site through the host file, othert than with pcwrt.
But i have a problem, there are sites that i can’t block through the host file.
For example, if i wanna block a site, i write into the host file in this way:
“127.0.0.1 www.jezebel.com” and it works.
but this method doesn’t work with all sites. Infact if i want to block a semi-adult site like “emmreport.com” , i can’t.
I tried in every possible way, writing, for example:
127.0.0.1 https://www.emmreport.com/
127.0.0.1 http://www.emmreport.com/
127.0.0.1 https://emmreport.com/
127.0.0.1 http://emmreport.com/
127.0.0.1 emmreport.com/
NOTHING, the site is not blocked. If i insert 10 sites into the the host file, 7 sites are normally blocked, and 3 not.
I tried to replace 127.0.0.1 to 0.0.0.0, no one result
What can i do?
This topic was modified 7 years, 7 months ago by
Casino.
Casino.
