Thanks. Under Settings > Internet, the only field that is set is Protocol and it is set to DHCP client. Override MAC address is empty.
I just had another major reconnection outage. It occurred when I was testing using my iPhone as a hotspot. To do that, I had to turn off WiFi on the router on the 2.4 GHZ and 5 GHz bands. When I reenabled each band, it didn’t allow any traffic through. I power-cycled the cable modem, pcwrt router, PC dock, PC, etc. All LEDs on modem and PCWRT said there was internet, but my computers couldn’t connect by LAN or WiFi. Here is what ChatGPT said on analyzing some of the logs:
Key observations from your log:
1. WAN interface flapping (up/down repeatedly):
2. netifd: wan (…) udhcpc: started
3. udhcpc: sending discover
4. …
5. udhcpc: received SIGTERM
6. netifd: wan (…) Command failed: Permission denied
7. netifd: Interface ‘wan’ is now down
8. kern.info kernel: mt7530 … wan: Link is Down
o The WAN interface (wan) comes up (link detected, 1Gbps full duplex), but as soon as DHCP (udhcpc) tries to get an IP from your ISP, it gets terminated.
o This repeats in a loop: link up → DHCP discover → SIGTERM/Permission denied → link down.
9. LAN & WiFi are fine:
10. dnsmasq-dhcp … DHCPACK(eth-lan.10) 192.168.10.201 …
o Your LAN/WiFi clients are getting IP addresses from the router with no issue.
o So DHCP/DNS internally is working; the problem is only between router ↔ modem.
11. The critical error is:
12. netifd: wan (…) Command failed: Permission denied
o That’s unusual — it suggests either:
A permissions/config error inside OpenWrt/pcWRT (netifd can’t control udhcpc correctly), or
A firmware bug that kills the DHCP client process prematurely.
13. ISP DHCP not reached:
o I don’t see any successful DHCP offer from the ISP.
o Compare to when you plugged your laptop directly: it worked, so the ISP will issue an IP — but it may only allow one device at a time by MAC address.
I can send you a log separately if that would be helpful.
I plugged in my PC directly into the modem with Ethernet (bypassing pcwrt router) and the PC worked fine. I turned off the modem for a few hours. Then I powered up the modem, connected the router to the modem, and the PC to the router. All was okay.
Thoughts?
