The changes for this release are:
- Bug fix for time control (e.g., Steam can be played in blocked time range).
- Bug fix: status page failing to show connected devices in certain scenarios.
- Changed guest network connection type. If you have an existing guest network, you need to recreate it after this update: go to the Wireless Settings page, remove the guest network, Save. Re-create the guest network, Save again.
To update to this version, click the “Check for Updates” button in the System settings page.
