Changes included in this update:
- UI update: add dialog to display system logs – on the Status page, click on the “System Log” link on the top right corner to bring up the dialog.
- UI update: change Ethernet port numbering on the UI to match port marks on the router box. Previously, the UI assumed that the ports were numbered 1,2,3 etc., from left to right. With this change, the ports are numbered to match the marks on the router box. For example, if the left most port is marked “LAN 3” on the router box, it is now port 3 on the UI.
- Add support for VPN split tunneling by country code (e.g., use geoip:CN for China IP addresses, where CN is the two-letter country code)
- Bugfix: Wireless Settings cipher incorrectly displayed on the UI
- Bugfix: network error when no Ethernet port is assigned to LAN
- Bugfix: some HTTP pages fail to load with enforced Access Control when DNS ttl for the domain is too small (e.g., 1s)
- Bugfix: internal server error when saving wireless settings with one band disabled.
- Bugfix: Allow the WAN port to have VLAN ID 10 when it is tagged. When WAN has VLAN ID 10, LAN will take VLAN ID 11. Otherwise, LAN will have VLAN ID 10.
- Have your configuration backup ready. Create a backup file for your current configuration, if you don’t have one.
