There are two updates in this release:
- Bugfix: unable to upgrade system firmware in Access Point mode
- Add functionality to split tunnel between two VPN connections. Before this, you can only split tunnel between a VPN and your ISP connection.
This release supersedes v2.8.0, v2.7.9, v2.7.8 and v2.7.7, i.e., if after upgrading you want to roll back, you’ll roll back to v2.7.6.
- Have your configuration backup ready. Create a backup file for your current configuration, if you don’t have one.
