Home Forums General Configuration Question on Router Access and device isolation
  • #6488
    koningskruid
    On the diagonal of the VLAN access matrix you can toggle device isolation on/off in that VLAN.
    If you set device isolation in the VLAN “LAN” on, does that imply that you can not manage the router ?
    (Managing from another VLAN is not possible as the router can only be accessed from the VLAN “LAN”).
    #6493
    If you set device isolation on “LAN”, devices connected to LAN can still access the router. But they can’t talk to each other.
