Quote
#6460
Additional Note: The VLAN ID for the LAN network has been changed to 10 for this release. It was 1 before this release, and it was causing compatibility issues since VLAN ID 1 is reserved in some systems.
“Are you talking about the VLAN from the internet section part under “DHCP Client”? the part that says “If your ISP uses a VLAN, enter it here”
If so, is there conflicting issues if the ISP is using VLAN 10?
came across the issue with the new update which locks out and assigns a 169.x.x.x number.
Can you reupload the previous firmware which worked!
