Home Forums General Configuration Using Airports as extenders
  • #4422
    moral
    I see the forums say that Apple airports can be used as extenders when plugged into the pcwrt in 2017, has anything change since then where Airport products can be configured to extend the pcwrt wirelessly?
    Thank you.
    #4432
    It should still work when wired to the pcWRT.
    The ability to extend wirelessly is a function of the extender. It doesn’t not require any change on the pcWRT. You need to check the docs for the Airport and see if it supports running as a WiFi extender.
    • This reply was modified 5 years, 3 months ago by support.
