Home › Forums › Troubleshooting › VLAN Port 4 not showing
Hi,
VLAN Port 4 does not show up. I only have Ports 1-3.
I need help setting up network segregation. I have one desktop computer that is connected via ethernet to the router in Port 1. I would like it to be isolated from the rest of the network. Port 2 and Port 3 do not have anything connected but may be used in the future to connect a laptop or TV.
My remaining devices are wireless and I set them up to be isolated from each other.
What do I select for Port 1, 2, 3? I assumed LAN but I tried this and the desktop had no internet.
Unrelated:
I can’t add additional VLANS. The “+” does nothing.
I set Cipher to AES. But when I save it reverts back to “auto.”
Thank you.
First of all, you should have Internet no matter which VLAN you choose for the Ethernet port. But don’t tag the port though. And make sure that your computer is using DHCP, not static IP address.
For VLAN assignment, the basic idea is to put your most secure devices on LAN. Other devices go to other VLANs.
By default, devices on LAN can talk to each other, can initiate communication with devices on other VLANs, and can log in the router. Devices on other VLANs have access only to the IP address page and the Ad block control page on the router – they can’t see the login page.
So if your desktop PC connected to LAN port 1 is a trusted device then port 1 should be assigned to LAN. If it’s a risky device that provides services to the public Internet, then it should be assigned to another VLAN and be isolated from the rest of your network.
For WiFi, you can create up to 4 SSIDs each band, assigned to different VLANs. It’s a know bug that Cipher always displays “Auto” even when configured as “AES”. This will be fixed in the next update (coming soon).
Could you explain what you mean by not “tagging” the port?
Do I have to create anything else to isolate the only device, a desktop, that will be plugged into one of the three ports via ethernet?
Where do I check DHCP?
I can’t add additional VLANs. The “+” button does nothing. I had only created three VLANS. I can not add a fourth.
When connecting wireless devices to the VLANs I created do I input the “key” or password I created for that VLAN or do I use the wireless password?
If X1 is a laptop that is used both wireless and via ethernet does that mean that I would have to assign one of the three ports on the router to “X1” to keep it isolated? I am having trouble understanding the relationship between the Ports and the VLANs I have created. All of my VLANs have been isolated from one another.
Thank you
Let’s talk about WiFi first.
You can have up to 4 SSIDs per band for WiFi. The WiFi for the LAN network always exists and cannot be deleted. So you can add up to three SSIDs per band. After that the “+” button is no longer active.
Let’s say you added an SSID “guest-wifi” to the Guest network with WiFi password “youarewelcome”, then when you connect a device to that SSID with the password “youarewelcome”, that device will be on the Guest network (or Guest VLAN).
Is that clear?
Yep, I think so.
Could you answer the other questions, please?
Thank you.
Are there instructions online showing how to set-up this router?
Here are some guides: https://www.pcwrt.com/support/
Back to your original questions:
1. Tagging: on the Network Settings page, under the VLAN section. There’s a checkbox named “Tagged”. You check the box to “tag” a port. You don’t want to check this box unless you are connecting another router or a VLAN aware switch to the port.
2. DHCP: your computer is configured to use DHCP by default. I.e., it will ask the router to assign it an IP address etc. But sometimes people change the network settings on the computer for it to use a specific IP address (i.e., a static IP address).
3. VLANs: on the router, VLANs are assigned to the LAN ports or WiFi SSIDs. When you connect a computer to a LAN port on the router, the computer will be on the VLAN assigned to that port. When you connect a computer to an SSID, then the computer will be on the VLAN associated to that SSID. Let’s suppose that LAN port 1 is assigned to the “LAN” network and SSID “pcwrt-x1” is associated with the “X1” network. When you connect a computer by Ethernet wire to port 1 AND connect by WiFi to “pcwrt-x1”, then your computer will be on both the “LAN” and “X1” networks (for example only. I don’t see why you would want to connect a computer that way).
I can’t log into the router. I am unable to get to the login screen. 192.168.10.1 gives me a screen with pcWRT “My local IP address” and “adblock control.”
I initially set up this router by connecting it to my existing router. But this was the first time I attempted to connect to it after connecting it to my modem.
Your computer needs to connect to LAN and have IP address 192.168.10.x in order to manage the router. If your computer is connected to other VLANs, such as Guest, X1, etc, you’ll see only “My local IP address” and “adblock control.”
If you’re connecting by wire, try switching to a different LAN port.
It is connected to LAN via wire. I tried other LAN ports and get the same message.
Nevermind, I think I fixed this. Thank you.
Why does the VLAN setup show “X3” in the diagram but there is no “X3” under wireless settings/wireless networks?
