Home Forums Miscellaneous What are the maximum speeds of PW-AX1800?
  • #6444
    silviu_25
    Hi,
    I’m wondering what are the maximum speeds for PW-AX1800 with:
    WireGuard enabled
    WireGuard disabled
    Enforce Access Control enabled and WireGuard enabled
    Enforce Access Control enabled and WireGuard disabled
    On a 1000 mbps connection from ISP with those options enabled can achieve anything nearly 6-800 mbps?
    Also having the Internet Logs enabled at all the times, that will reduce the performance of the router? Speed?
    Or will wear the internal memory?
    And for how long the logs are kept?
    Thanks
    #6450
    Without WG, the max speed is 1000Mbps, with WG the max is 500Mbps. Enforce Access Control does not slow down the speed. Logs are kept in memory with a fixed size. You can look back up to 24 hours, but if there are a lot of Internet activities, it may not have enough memory to keep the full 24 hours.
    #6451
    silviu_25
    Thanks but on this post: https://www.pcwrt.com/forums/topic/slow-speeds/#post-5250
    You said that “The speed will be reduced when you “Enforce Access Control””
    #6452
    @silviu_25 That was for an older model with a less powerful CPU. The AX1800 has a quad-core 1.2GHz CPU and Access Control does not slow it down.
