Home Forums Troubleshooting WiFi Calandar Scheduling Stopped working
  • #6360
    MarKStan
    Wifi Calendar was working with v2.5.8 not sure exactly when it stopped. Now using v2.6.4. Also now only have 5ghz radio enabled. There were other configuration changes made between v2.5.8 till now. For debugging: 1) Have tried enabling 2.4ghz radio again and 2) deleted all entries from the Wifi Calendar and then added them back in. However the SSIDs broadcast all the time even though “Limited Time” is selected. Help would be appreciated.
    #6363
    Is 2.4 GHz WiFi working now?
    #6364
    MarKStan
    Yes 2.4 ghz works. Its simply not needed in my setup, so I have it disabled.
    That being said, I can nolonger get the Wifi to turn off by following the steps in “Turn off WiFi router automatically at night” Posted by pcwrt in Router, WiFi on July 22, 2018. Thank you.
    #6365
    Can you send a copy of your backup file to [email protected] so that we can test it out?
    #6378
    markpenn2020
    I’ve been having the same problem. Both 2.4 and 5.0 work, but neither will shutoff like they used to. I think I’m on 2.5.9. I also noticed that if I setup an access control group to bypass the router level OpenDNS to use Google DNS (for my work VPN and VOIP device), it still uses OpenDNS.
