Home Forums Troubleshooting Wireguard VPN LAN access
  • #6750
    Motive6875
    I am having issues remote accessing into my computer while connected through wireguard vpn into my home network. I can access my computer while directly connected to the network.
    I have a PW-AX1800 on firmware version v2.7.6.
    #6759
    On the WireGuard server configuration page, under the Network Access section, you need to check the VLAN your computer is connected to. E.g., if your computer is connected to LAN, then you need to check the LAN box. Also, the remote connection cannot be “Guest”.
    #6760
    Motive6875
    I did all that. It started to work after a restart.
