I am looking to increase my networks wifi strength and stability with some hardwired access points. The Engenious APs have a feature called SSID to VLAN tagging and cross band vlan pass through. My understanding is that the APs ‘tag’ traffic with a selected SSID and pass it through to the switch in order to distinguish vlan networks.
Would this be compatible with the pcwrt and a network with multiple vlans? If so do you have any info/instructions on setting it up?
EnGenious Specs:
https://www.engeniustech.com/wp-content/uploads/2018/11/Neutron_Series_IndoorAP_11ax.pdf
Thank you!
