1. Is AdGuard VPN compatible with your router?
I messaged AdGuard about it & they said their very own VPN protocol isn’t compatible until it’s open source. But they never mentioned the fact that they allow IPsec/IKEv2 capabilities in their own VPN apps, which I believe is separate from their own protocol. Does this mean it can probably be configured in VPN routers somehow, maybe?
2. When will your products be back in stock? What’s the average time your products are restocked? Or are you releasing a newer/improved model?
I was looking around for your products and found a different model not listed in your site:
Another site had it listed for ~$200, but I don’t know if it’s a scam.
If it’s not a scam, what’s the difference between that one and the one listed in your site for $129? Is it older, newer, updated, etc.? The one from Amazon never mentioned anything about Wireguard & IKEv2.
Thank you for reading.
