Home Forums Troubleshooting Can’t connect Macbook Pro
  • #2792
    zoonooz
    Hi. I am able to connect my iPad to the router, but I cannot connect my Macbook Pro. It says “The Wi-Fi network “pcwrt”could not be joined.” I’ve reset my router, deleted the network from the Macbook and restarted everything multiple times but the Macbook Pro won’t connect. I am on Mojave 10.4.2.
    #2797
    Were you able to connect to the router before? Is this a new machine? Would you be able to connect if you remove WiFi encryption?
    You may also try this: https://apple.stackexchange.com/questions/307690/get-rid-of-the-wi-fi-network-could-not-be-joined-message
    • This reply was modified 7 years, 1 month ago by support.
