Log inRegister
Home › Forums › General Configuration › Changing Signal Login Password for Devices After Initial Setup
I did the initial password setup – now how do I change it? I’m talking about the password people use to access the WiFi signal.
Log in the router management console. Click the Wireless icon. The WiFi password is the Key field in the Wireless Security section.
Thanks! I did it, but now its been “applying changes” for a long time.
Since the WiFi password is changed, you need to reconnect with the new password.
If the old WiFi password is remembered by your computer, you might need to “forget” the old password first.
Looks like it’s working. Thanks again!
