Log inRegister
Home › Forums › Device Setup (printers, IP phones etc.) › connect pcwrt to orbi
This topic contains 4 replies, has 3 voices, and was last updated by support 2 years, 3 months ago.
I have had pcwrt, but recently bought orbi with one satellite to get better wifi through house. Can I still use pcwrt for parental controls while using orbi to extend wifi?
You can try this configuration:
You’ll use WiFi from the Orbi only and your devices will appear as wired connections to the pcWRT.
For more info on how to run the Orbi as AP: How do I configure my Orbi router to act as an access point?
thank you – it worked!
what about easymesh? https://www.wi-fi.org/discover-wi-fi/wi-fi-easymesh
@rjager The type of mesh doesn’t matter. The requirement is to run the WiFi mesh in bridge mode.
