Home Forums Troubleshooting DHCP Limit Question
DHCP Limit Question
This topic contains 3 replies, has 2 voices, and was last updated by  support 1 year, 2 months ago.
  • #4859
    WarrenHolt
    On the Network Settings page, the “DHCP Start” is pretty self-explanitory but does “DHCP Limit” mean the 1) maximum number of DHCP leases that will be allowed (e.g. DHCP Start = 180, DHCP Limit = 10, Last possible DHCP lease is 189 (inclusive)) or does it mean 2) the RANGE of DHCP leases (e.g. DHCP Start = 100, DHCP Limit = 150, Maximum number of DHCP leases allowed = 51 (inclusive) from 100 to 150).
    #4862
    Limit specifies the size of the address pool. E.g., with start=100, limit=150, maximum address will be 249.
    #4863
    WarrenHolt
    Ok, I understand. Thanks.
    Now I assume Static Leases do not need to remain within that range. Should they always be kept OUT of the DHCP range (e.g. the two never overlap)?
    #4864
    You don’t need to keep static lease out of the range. In fact, the easiest way to assign a static IP is to set a host name from the Status page, which assigns the host’s current dynamic IP as its static IP.
