As described in our blog post, as a home user, you can use OpenDNS in two ways: OpenDNS Family Shield or OpenDNS Home. The former does not need a login to OpenDNS, while the latter requires you to set up a free account with OpenDNS.
If you decided to use OpenDNS Family Shield, it takes a single step to use OpenDNS in pcWRT: just select “OpenDNS Family Shield” in the DNS Server dropdown in a profile under Parental Control Settings.
If you want to use OpenDNS Home, there are five steps:
- Sign up for an account at OpenDNS.
- Set Dynamic IP Update for OpenDNS.
- login to OpenDNS
- click the Settings tab
- Select your home network in the Settings for dropdown
- Click Advanced Settings
- Check Dynamic IP Update
- Log in to https://www.dnsomatic.com/ with the same OpenDNS username and password. Add the OpenDNS service.
- Log in to pcWRT router management console, click Dynamic DNS, select dnsomatic.com from the Service dropdown, then enter your OpenDNS username and password. Click Save.
- In pcWRT Parental Control settings, select OpenDNS Home from the DNS Servers dropdown.
This topic was modified 10 years, 6 months ago by
pcwrt.
