Log inRegister
Home › Forums › Device Setup (printers, IP phones etc.) › LTE SIM
This topic contains 3 replies, has 2 voices, and was last updated by support 2 years, 8 months ago.
I have an LTE SIM CARD for hotspot. How can I use it with TORONTO-AC Router as internet source?
Do you mean insert the LTE SIM card into the TORONTO-AC Router?
Correct, either directly or via an adapter?
Currently, the router only accepts Ethernet connection to the WAN port for Internet. So if you have an LTE hotspot, you need to connect the TORONTO-AC WAN port to the Ethernet connector on the hotspot.
