Hello. I have a Synology DS220j. It’s just an entry level NAS device you can buy anywhere: https://www.synology.com/en-us/products/DS220j. I’m trying to understand how to configure my network settings so that my different devices can see the NAS. The NAS device is connected to the pcWRT via ethernet cable to the port labeled LAN 1. In my VLAN settings page, I have the entire LAN row and column checked, so that LAN is accessible to and from every other VLAN on the network. But none of my devices are able to discover the NAS, unless I am plugged into the router using an ethernet cable. Is that right? Are there other settings that I should investigate on the pcWRT?
This topic was modified 3 years, 3 months ago by
y1kfwg2b.
