By default, parental control is disabled:
To enable parental control:
- Click the Enable button
- Leave “Safe Search”, “Block literal IP addresses”, “Block proxy, VPN, TOR” checked
- Select OpenDNS Family Shield or OpenDNS Home from the DNS Servers dropdown.
- Click the Save button.
Result:
- Web contents filtered through OpenDNS.
- Safe search enabled.
- DNS bypassing techniques blocked.
- Proxies, VPN and TOR bypassing blocked.
- All devices in your wifi network follow the same policy.
Once you are familiar with the minimum configuration, you can create additional profiles for more more flexible controls.
This topic was modified 10 years, 8 months ago by
pcwrt.
pcwrt.
