There are two fixes in this release:
- Fixed connection problems with Xbox, Steam etc.
- Fixed a bug in the Status page where some connected devices fail to display (e.g., Xbox connected via wire).
If you updated from a version earlier than v1.21.2 and have an existing guest network, you need to recreate it after this update: go to the Wireless Settings page, remove the guest network, Save. Re-create the guest network, Save again.
To update to this version, click the “Check for Updates” button in the System settings page.
