The changes for this release are:
- Fixes for connectivity problems with Xbox, Steam etc.
- Fix for problems in the Status page (Xbox not displaying).
- Updates to make the router work with devices with Barracuda Network solutions installed.
- Add YouTube moderate restricted mode.
If you are updating from a version earlier than v1.21.2 and have an existing guest network, you need to recreate it after this update: go to the Wireless Settings page, remove the guest network, Save. Re-create the guest network, Save again.
To update to this version, click the “Check for Updates” button in the System settings page.
