There are two changes in this release:
- Add YouTube moderate restricted mode.
- Fix a problem with Xbox connectivity.
If you are updating from a version earlier than v1.21.2 and have an existing guest network, you need to recreate it after this update: go to the Wireless Settings page, remove the guest network, Save. Re-create the guest network, Save again.
To update to this version, click the “Check for Updates” button in the System settings page.
