Changes included in this update (v1.28.1):
- Add OpenVPN server and client. The OpenVPN server allows you to establish a secure VPN connection back to your home network from the Internet. The OpenVPN client allows you to tunnel traffic from your home network to a remote OpenVPN service. If you created multiple VLANs or WiFi networks on the router, you can select which network(s) to tunnel through the VPN service. DNS leak prevention and VPN kill switch is built-in and requires no additional configuration.
- Increase the maximum number of WiFi networks from 2 (i.e., LAN and guest) to 4.
- Add Cloudflare DNS, Quad9 and CleanBrowsing Family to the list of DNS service options.
- Add option to override router Reset button. You can override router reset button under the Notifications section on the System Settings page. You need to check both options “Allow router password reset on login page” and “Override router Reset button”. If someone presses the Reset button on the router when those options are enabled, the router will not reset. It will simply send an email notification to your configured email address. In case you need to recover the router password, you can click the “Forgot Password” link on the Login page to have the router reset the password and send to your email.
- Fix a bug in Access Control that blocked multiplayer games
- Fix a bug in remote management that delayed router rebooting
