Home Forums Announcements pcWRT firmware v2.4.1 Release Notes
Viewing 9 posts - 1 through 9 (of 9 total)
  • #4577
    Changes included in this update (v2.4.1):
    • Add split tunneling capability to VPN clients. Now you can enter a list of destination domain names or IP ranges to exclude from the VPN connection. Or the reverse: use the VPN connection only for the specified domain names or IP ranges. The regular expression syntax for Access Control lists also work in this area.
    • Minor bug fixes.
    #4595
    BashDashovi
    I’m having the weirdest issue with this update. Every morning since updating, all Amazon echos in my house report that they are not connected to the internet, while other devices have no issue. Rebooting or moving a device from one profile to another and hitting save restores their connectivity. Any idea how to debug this?
    #4596
    @BashDashovi Is Ad blocking enabled on the profile? If so, check the Internet logs for which domains required by Echo was blocked as Ad. Post those domains here and we’ll remove those from the ad blocking list.
    As an immediate test, you can create a separate profile for the Echo devices and disable Ad blocking for the profile.
    #4601
    BashDashovi
    No ad blocking on any profile. This morning the one Echo I moved to a new profile was still connected to the internet but the others that remained on the Default profile all claimed to be disconnected. I didn’t find any blocked sites for any of them in the logs over the previous 12 hours. Once again, moving one device from one profile to another and hitting save connected all devices. The default profile has Access Control enforced and safe search and is using OpenDNS Family Shield for DNS.
    #4602
    @bashdashovi You may try putting all Echo devices in a dedicated profile and selecting a non-filtering DNS such as 1.1.1.1.
    #4603
    BashDashovi
    It turns out that the issue is not limited to Echos. All devices that are on profiles with calendars will not have internet access once their time is back. For example, I have a laptop on a profile that stops access at 10pm and restores it at 6am. At 8:30am, the laptop still does not have any internet access. It is listed as connected to the router in Status, but nothing shows up in the Access logs, blocked or otherwise, after the internet should have come back on for it. I DO see blocked requests during the calendar outage period with the blocked reason “Calendar”.
    It looks like once the calendar time starts for a profile, the router instead stops honoring any requests from devices on that profile.
    #4607
    @bashdashovi There’s probably something else then. We didn’t have any problems with calendars keep blocking when they’re supposed to be back on. The last update did not touch the Access Control functions either.
    Can you send a copy of your backup file to [email protected]?
    #4765
    Barry_dudley777
    How long does the update take? Mine says the upgrade file is corrupted, but then it looks like it’s flashing the update to the device anyways, but it never seems to finish the flash upgrade. Is it possible to download the flash upgrade for the firmware and do a manual upgrade?
    #4778
    knoxploration
    Ever since this update, managing through the pcwrt.com website stops working for me after an indeterminate period of time. I get a notice that the router isn’t available, although it is currently online. Rebooting the router fixes the problem. Anyone else experiencing this? I never saw it prior to the last update but have seen it several times in the past few weeks.
