Changes included in this update (v2.5.2):
- Improvements on DNS over HTTPS (DoH) handling
- Block VPN users without LAN access from the router login page
This update supersedes v2.5.1, i.e., if you decide to rollback from this version, you’ll rollback to v2.4.8.
