Changes included in this update (v2.5.3):
- Add VLAN tagging support for the WAN port
- On the Network Settings page, add option to turn on NAT offloading (network performance improvement)
- Some bug fixes, including server error message when disabling VPN server
This update supersedes v2.5.1 and v2.5.2, i.e., if you decide to rollback from this version, you’ll rollback to v2.4.8.
