Changes included in this update (v2.5.8):
- Bugfix: domains inadvertently blocked when block TOR/VPN is checked
- Bugfix: CF-XR10 LED for LAN not lighting
- Internet access log raw mode rendering improvement
- Allow white list override of implicitly blocked search engines
- Avoid DoH fallback to unencrypted UDP/TCP mode
This release supersedes v2.5.6, meaning, if you do a rollback, you’ll rollback to version v2.5.3.
