Home Forums Announcements pcWRT firmware v2.7.5 Release Notes
  • #6459
    Changes included in this update:
    • Add WiFi WPA3 encryption support for AX1800 and CF-XR10
    • VPN update: allow VPN server user configuration to choose which VPN client to tunnel out
    • VPN update: allow VPN client configuration to force the use of VPN DNS service
    • Add support for Access Point mode. The router running in Access Point mode will provide WiFi access only to extend the WiFi range. It needs a wired connection to the main router running in router mode.
    • Bugfix: WiFi not turned off as defined in WiFi calendar.
    • Other UI bug fixes
    1. Have your configuration backup ready. Create a backup file for your current configuration, if you don’t have one.
    3. After successful upgrade, create a new router settings backup file from the System Settings page and save it in a safe place
    #6460
    Additional Note: The VLAN ID for the LAN network has been changed to 10 for this release. It was 1 before this release, and it was causing compatibility issues since VLAN ID 1 is reserved in some systems.
    #6470
    We just put in a fix to the bug where disabled WiFis were activated without password during upgrade. The version number has been bumped to v2.7.6.
    #6520
    Please refer to this post on how to set up the router as an Access Point: https://www.pcwrt.com/2024/12/how-to-set-up-a-second-pcwrt-router-as-an-access-point-with-vlan-support/
