Home Forums Parental Control PCWRT is hackable
PCWRT is hackable
  • #370
    jasonlee106
    I recently learned that my kids were able to hack into PCWRT by placing a spacebar in the password field and pressing the Enter key and they were able to login into the administration web page. Can anyone else try this and see. Is there a firmware to fix this?
    #371
    @jasonlee106 This should not be possible. Did you try to log in with just a space? Did that work for you?
    If you can log in, I’d suggest that you change the password in System Settings: click “Change Router Password” in the Administration section. After you change the password, try to log in again with a space bar. Let us know if that works.
    #372
    jasonlee106
    Yes I am able to login with just a space. I even tried it with 2 spaces and 3 spaces and they all allowed me to login. I changed the password 3 times to a very strong alphanumeric password and I was still able to login with a space. I am also able to login with the newly changed password as well. This is not very secure as my kids were able to figure this out.
    #373
    Thank you so much for the feedback. We were able to reproduce this. A fix will be sent out by tomorrow.
    • This reply was modified 10 years, 1 month ago by support.
    #475
    bogboy
    fix?
    #482
    @bogboy Please send email to [email protected] if this is an urgent issue. If not, we have a major update coming in a couple of weeks. Thanks!
    #535
    @bogboy Please download version v1.20, where this problem is fixed. The steps for upgrading is posted in Announcements. Thanks!
