Home Forums Troubleshooting pcWRT on Linksys WRT1900ACS V2 ?
  • #4897
    whiteseed
    Hello. I’m interested in installing pcWRT on my Linksys WRT1900ACS V2 and noticed under downloads you have the Linksys WRT1900ACS listed, but I just wanted to make sure it was compatible with the V2 model?
    Also i assume if that is the case I just flash the Factory: WRT1900ACS-v2.4.5-factory.img then the Upgrade: WRT1900ACS-v2.4.5.bin? or do I only need one file?
    Really appreciate a response. pcWRT seems to be exactly what i’ve been looking for.
    #4898
    @whiteseed The image is compatible with WRT1900ACS V2. If you are flashing from stock firmware, use the Factory image (no need to flash upgrade again after that). If you are upgrading from an existing OpenWrt installation, then use the upgrade image. Please checkout the OpenWrt website on how to flash from stock firmware.
