Home Forums Feature Suggestions Port Blocking within the “Access Control
  • #6145
    bolozinaction
    What is the input format to block ports?
    I want to perform a test to block certain ports using the different VLAN ports, I am assuming you can block it from the whitelist/blacklist section? With the correct input format?
    • This topic was modified 1 year, 11 months ago by bolozinaction.
    #6149
    Entering :80 blocks port 80 for both TCP and UDP, :80U blocks UDP port 80, :80T blocks TCP port 80. More info here: https://www.pcwrt.com/2020/01/how-to-allow-or-block-web-sites-on-the-router/
