PCWRT:
It appears that the parental control “Sites” field does not accept a port range (IP ranges can be specified with CIDR), is that correct? Can that feature be added (for example :3000-4000)?
This is supported as of version 2.0.3. You can enter port ranges like this “:3000-4000” for both TCP & UDP, “:3000;4000U” for UDP only, and “:3000-4000T” for TCP only.
