Home Forums Troubleshooting problem on Config IKEv2
This topic contains 4 replies, has 2 voices, and was last updated by  support 1 year, 3 months ago.
  • #4796
    Ramazanpour69
    Hi,
    I would like to config my strongswan Ikev2 vpn account on router. but I get that account with EAP authentication method. but the router Ask me dor .pem file. I haven’t that.
    is there any way to config the VPN just with EAP authentication without any certificate or pem file?
    #4802
    Who’s the VPN provider?
    #4804
    Ramazanpour69
    They are not big such as Strongvpn…
    but they only support EAP auth.
    EAP is using in android, windows …
    #4824
    Ramazanpour69
    Any Solution?
    #4833
    EAP is supported. That’s what the username and password fields are for. The PEM/DER requirement is for server authentication. The VPN provider should provide the certificate file. For example, you can search for “protonvpn ikev2 certificate” to get the DER file for ProtonVPN. Other VPNs may use a trusted CA to sign their server certificate. You’ll need to find out what it is and upload that.
