Is there a way to remote access the ‘Apps’ section of the PCWRT router? Like, checking if the Wireguard connection at home has dropped or not.
Or can you push that onto next firmware update?
You can set up a VPN server on the router. Check the LAN box under the “Network Access” section (also the Internet box if you want to access the Internet through the home VPN). Connect your remote device to the VPN and you should be able to manage the router like you are at home.
