Basically when you first configured for remote control, you can access it. But then after a while, you get the “Failed to retrieve data” error, without doing anything. For example, you set it up in the morning, test immediately and it works. But then in the afternoon, try it again it fails. Is that right?
Is the pcWRT router connected to another router? Or is it connected to a modem?
