Is there any way to separate out the Block Proxy,TOR,VPN function? It seems that it has to be unchecked for the XBoxOne to work. Do you know why that is? In any case, I think that my son is getting around the calendar controls that block xboxlive.com, etc. by using a VPN. If the Block Proxy,TOR,VPN control was separated, then I could just block VPN.
What is the preferred method to control access to Xbox Live? I’m allowing xbox-live.com and xboxlive.com with the calendar. “Block Proxy,VPN,TOR” is unchecked.
Thanks!
