Glad to know you got it working! BTW, if you are putting Access Control on devices, you might want to check if the MAC address changes when connecting from the range extender. If so, you may need to assign the new MAC address the same device name as when the device connects directly to the router. That way, the device will be identified by the same name whether it’s connected directly to the router or connected through the range extender.
