I’m trying to configure the Ethernet ports on my CF-XR10 router to associate them with the following available VLANs:
– Port 1: LAN
– Port 2: X1
– Port 3: X3
When I click the “save” button, the page indicates “Applying changes,” and after a while, it says “Changes successfully applied.”
However, the Ethernet port configuration then displays:
– Port 1: LAN
– Port 2: Guest
– Port 3: X1
I’ve tried connecting via Wi-Fi and wired connection, but I get the same result.
I’ve disabled ad-blockers on the Brave browser and also tried with Firefox, but the outcome is consistent.
I’ve even performed a factory reset of the modem, but the issue persists.
I tested applying the following configuration, and it works:
Port 1: LAN
Port 2: LAN
Port 3: LAN
However, when I try a configuration like this, for example:
Port 1: LAN
Port 2: X1
Port 3: LAN
The displayed Ethernet port configuration is then:
Port 1: LAN
Port 2: Guest
Port 3: LAN
The firmware update is v2.5.8 and I recently bought the CF-XR10 router directly from the pcwrt.com web site.
Do I need to do something special to associate ethernet ports with VLANs X1, X2, and X3?
Thanks!
