Home Forums Troubleshooting Wifi for OpenAccess Connection
  • #4973
    HDCerberus
    I have enabled the OpenVPN server. However, while all works well, there seems to be no indication of which VLAN the VPN connects to.
    When connected via VPN, am I connected to the LAN, X1, X2, or X3.
    When using the client option, I can select a VLAN to enable it for, but the server doesn’t seem to have such options.
    #4976
    When you connect as a VPN user to the VPN server, you have access to all internal networks (LAN, X1, X2, X3, etc) as well as the Internet.
    But you can specify a user as a guest. In that case, he can only connect to the Internet, not the internal networks. In an upcoming release we’ll add the option to choose which network(s) a VPN user can have access to.
    #4984
    HDCerberus
    There is something wrong here then. I have a user using OpenVPN who is not a guest:
    OpenWifi
    I’ve got a few VMs running things like Sonarr, and I have the network up with the default config (LAN source can reach LAN destination and so on): . When my phone connects to the Wifi connection labelled as ‘LAN’, I have no issue connecting to Sonarr + the other VMs running similar apps restricted to LAN.
    When I move my phone to cellular data only, and connect to the network via the OpenVPN server, I am not able to access devices restricted to the ‘LAN’. I can connect to the OpenVPN Router no issue, but pinging anything on the network *at all* fails.
    • This reply was modified 4 years, 2 months ago by HDCerberus.
    #4989
    What do you see when you ping the router LAN IP?
    #4995
    HDCerberus
    I get a ping response, and I can easily reach the web page:
    #5004
    The next test would be trying to ping your VMs, with the ping command. Do you get a response?
    If not possible to run “ping” from the smartphone, you can use a computer with the smartphone’s WiFi hotspot, run the OpenVPN client on the computer.
    #5008
    HDCerberus
    No, as I said in my second comment, longing literally anything else fails. The only thing that works is internet.
    #5010
    Can you attach a screenshot of the “ping” command?
    #5019
    HDCerberus
    I mean, sure. Here’s a screenshot of the failed ping:
    #5020
    What’s your network setup like? Is your LAN network on 192.168.0.x, and the VMs are on the same subnet?
    #5021
    HDCerberus
    Correct. Router is 192.168.0.1, and I have every other machine running on 192.168.0.X. The one I pinged for example wired to the ‘LAN’ network.
    I’ve checked today, and I have no idea why, but it’s suddenly begun to work. I’d preveiuously tried restarting the service, and the router, and the machine running the VMS, and pretty much everything under the sun, but it hadn’t worked. Today it suddenly decided to, I get a response and the network responds as expected…
    I have no idea why, but case closed I guess.
