Home Forums General Configuration Wireless vlan and reduced power
  • #4222
    timbo777
    Does using/turning on all the wireless vlan networks reduce the range and speed of individual networks? ie having one main wireless network stronger and faster vs 5 wireless networks that become reduced in speed and range.
    By that notion would there be incremental differences by reducing one network at a time? ie reducing from five to 4 to gain a slight increase in power?
    Thank you
    #4224
    The range should not be affected. When you create multiple SSIDs, they are basically time-sharing. BTW, what kind of range are we talking about? Are there any concrete walls?
    #4225
    timbo777
    Thank you.
    We’re talking about 50-75 ft. No concrete walls but some aluminum siding to reach one exterior area.
    #4227
    Sounds like pretty long distance. I’m not sure how much signal degradation there is, but if the signal strength is > -80dBm range, you may get pretty good transmission speeds by trying different channels.
    #4230
    timbo777
    what kind of average distance should the pcwrt be capable of for 2.4 and 5 ghz networks?
    #4231
    We have reports of up to 50-feet distance two story house without needing WiFi extenders. For longer distance, the 2.4Ghz channel works better. The number of walls between the router and the device plays a big role. But usually the signal strength is a good indicator (check the Status page, need to be >-80dBm to get decent transmission speed).
    Picking the right channel is important if there are a lot of WiFi signals around your house. On the far end, your neighbor’s signal might be stronger than yours. Please check out this post: https://www.pcwrt.com/2017/10/how-to-avoid-bad-wifi-connection-by-changing-the-channel-on-your-router/.
