Home Forums Announcements pcWRT firmware v1.27.1 Release Notes
  • #2458
    Changes included in this update (v1.27):
    • Added WiFi client isolation option to guest wireless network.
    • Added more VLAN options (X1, X2, X3 in addition to LAN and Guest) for Ethernet ports.
    • Added Ad Blocker. You can now block ads for a profile by checking the “Enable Ad Block” box.
    • Added functionality to temporarily extend WiFi time without changing WiFi schedule, from the remote management interface.
    • Added system configuration restore option to restore only Access Control settings, from the remote management interface.
    Incremental update v1.27.1 included:
    • Fix to a bug that caused malfunction when Access Control is turned off at router level.
    • Fix to a JavaScript error when all NTP servers are removed from System Settings.
    • This topic was modified 7 years, 4 months ago by pcwrt.
    #2495
    The support of this router is excellent! Thank you!
    #2507
    Email4him
    Great support.
    Here is some feedback.
    I noticed that this firmware update affected remote reboot from outside. When you try to reboot it will disconnect the remote session and it will take very long time before it initiate the reboot and comes back to the remote capability again. It might take 30 minutes or so.
    I have tested the reboot from inside the LAN and it is fast, the only issue is when you are remoting via the internet.
    When I revert back to 1.26.1 the remote reboot is restored and immediate. So this is only 1.27 (1) issue.
    #2510
    @email4him Thanks for your feedback. Will look into that.
    #2801
    Waiting for the new firmware. Thanks.
