Home Forums Announcements pcWRT firmware v2.0.6 Release Notes
Viewing 14 posts - 1 through 14 (of 14 total)
  • #3581
    Changes included in this update (v2.0.6):
    • WiFi performance improvement
    • Add Cloudflare for Families to DNS selection list
    • Add a link on the router login page to allow adblock pause/suspend/resume for each user, without needing to log in the router admin page.
    • Performance improvement for UDP sessions under Access Control (which affects passthrough VPN & gaming).
    • Fix bug in white listing when “Block proxy, VPN, TOR” is on.
    • Fix MTU bug which affected IPsec VPN client connections for some VPN services.
    #3666
    Added notes to explain the adblock pause/suspend/resume feature here: https://www.pcwrt.com/2020/05/block-ads-with-router/
    #3734
    When DNS Over HTTPS will be avaible at application level on browsers like Firefox or Chrome, parental controlo router as pcWRT, Koala Safe etc… will not filter anymore.
    What can you tell me about this? Is this real?
    #3736
    @casino You are right. Both Firefox and Chrome support DNS Over HTTPS (DOH). Here are the links for more info:
    Noticeably both browsers have some detection mechanism for managed networks, and will disable DOH when DNS filtering is detected.
    The pcWRT router has built-in defense against DNS bypassing techniques. Blocking will remain effective even with DOH enabled.
    #3737
    What can you say me about this:
    pcWRT Newifi-D2 Dual Band Secure WiFi Router
    is this a new router by you?
    #3743
    @casino That’s our new hardware.
    #3745
    Can you make a comparison table with the new previous modem? What are the advantages of this new hardware?
    • This reply was modified 5 years, 8 months ago by Casino.
    #3752
    @casino The hardware is equivalent to the TORONTO-AC. It has fixed antennas instead of detachable antennas. Flash is 32MB instead of 16MB for the TORONTO-AC.
    #3754
    The next time, PLEASE, add these:
    1) A simple power on/off button.
    2) A button for turn on/off the wi-fi.
    3) Slot for 3G/4G SIM.
    #3775
    I want to show your demo version with some people, but it’s really too old. Update it, please.
    #3777
    @casino Thanks for bringing this up. Will update soon.
    #3781
    @casino The demo site has been updated.
    #3922
    A friend of mine wants to buy your router. What are the benefits of increased memoery flash (From 16 to 32 Mb)?
    #3924
    @casino Thank you! Both 16Mb and 32 Mb are enough for current purposes. There’s no impact on performance.
