Home › Forums › Device Setup (printers, IP phones etc.) › Honeywell WiFi Thermostat
Hello, we have a Honeywell WiFi thermostat. It will not connect. I went through their configuration instructions as I’ve done before but the connection does not take. Confident I’m using the correct password.
Here’s the setup instructions… http://tomstek.us/change-wireless-network-honeywell-wifi-thermostat-rth8580wf/
Any reason this wouldn’t work?
Are you having trouble connecting to the WiFi, or you can connect but it didn’t function as expected?
If you can connect, the devive will show up in the devices page. And normally you’ll put the device in a profile without parental control.
If you cannot connect, you may want to try connecting without encryption first, then try different encryption options and see if you get different results. Thanks!
It seems that I cannot connect the Honeywell to the wifi. I’ll work on that again here.
I have another problem, and I’d like to also ask about this. I have a Republic Wireless phone and it cannot make or receive calls. So something is blocking the necessary ports. Here is the info on what ports need to be unblocked, according to their tech support:
Your Router or ISP must not block outbound traffic (from your phone) destined to the following ports
5090 UDP for call set up
6000-29999 UDP for audio
8883 TCP MQQT (used for Voicemail – MMS – SMS)
While other apps may use other ports. VoIP for our service uses 5090 and 16384 through 16402. That should be all that is needed to support voice.
5090 is for the SIP Signalling to setup and manage the call. and the ports 16384 through 16402 hold the actual audio. All of these ports are UDP not TCP.
The easiest way to make a Voip phone work is to set up a dedicated profile for the phone, and disable parental control for that profile. Let us know if that works for you. Thanks!
So there is one problem with that, which is that it is a Smart Phone with internet on it. I want it to be filtered, parental-controlled content. Can you help me to open those ports somehow please?
Also, the Honeywell thermostat is still not connecting properly. Do you have experience with this issue?
You can enable parental control for the phone, but uncheck the checkboxes “Block proxy, VPN, TOR” and “Block literal IP addresses”.
I have no experience with the Honeywell thermostat. Can you try setting up your Netgear as AP and connecting to that? In the meanwhile, we’ll do some research on the Honeywell thermostat.
Hi. I have unchecked those boxes. I have also tried to connect the phone and the t-stat to the Netgear AP. Still no luck here!
So the Netgear is hooked up as an access point, behind the PC wrt. So therefore if I understand correctly, the access point is subject to the same rules that are created by the PC wrt router. So what I think is happening right now is that the Honeywell Wi-Fi thermostat is also not able to connect to the internet because an IP address is being blocked. I have unblocked the 2 check boxes that you recommended for the user profile. The interesting thing is that occasionally throughout the day, I get an alert message saying that the Honeywell has reestablished its connection but then almost instantly I get another message saying that the Honeywell cannot connect. The messages saying that it cannot connect typically repeat every couple of hours. This is very strange behavior and I wish to solve it somehow!
Let’s take one thing at a time, the phone first.
1. Connect the phone to pcWRT, with parental control disabled for the router (i.e., default factory setting). Are you able to use the phone?
2. If above is yes, enable parental control for the router. Create a profile and put the phone in the profile. Disable parental control for the profile. Are you able to use the phone?
3. If above is yes, enable parental control for the profile, uncheck the two checkboxes I mentioned before. Are you able to use the phone?
Hello. I began diagnosing these steps. I discovered that when parental controls are turned off all the way, the phones both work. However now I have a new era. When I am trying to access the parental controls interface on the router I get this error.
Failed to execute controller function: ?:0: attempt to index field ‘?’ (a nil value)
stack traceback:
[C]: in function ‘assert’
?: in function ‘dispatch’
?: in function <?:338>
I have unplugged the router and plug it back in again. It appears that it is not loading now. That the DNS server is not working. Help please? Thank you.
Can you connect to the router and bring up the router management interface? If so, can you load the System page? If you can load the System page, please send a copy of your configuration backup file to [email protected], so that we can analyze this further.
If you cannot load the System page, you can reset the router to initial factory state and start over again. Follow the user’s guide to reset the router.
You may also reset the router if you want to start from the beginning and try to make some progress on your own. To keep things simple, work with the pcWRT router to begin with, don’t involve the Netgear initially.
pcWRT StatusSettings Pause Reboot Logout
Local Time: Sun Jun 26 09:07:10 2016 Uptime: 0h 1m 52s Load Average: 0.37, 0.24, 0.09
Internet
Type: dhcp
Address: x.x.94.194
Netmask: 255.255.248.0
Gateway: x.x.88.1
DNS 1: 8.8.8.8
DNS 2: 8.8.4.4
Connected: 0h 1m 26s
Wireless
2.4 GHz
2.4 GHz
SSID: Degnan
Mode: Master
Channel: 4 (2.427 GHz)
Encryption: WPA2-PSK
Connected Devices
Hostname IP Address MAC Address Network Signal
ABE-DellNotebook 192.168.10.168 xx:xx:xx:xx:xx:xx Wired N/A
AbePhone 192.168.10.169 xx:xx:xx:xx:xx:xx Master
“Degnan” -83 dBm
KidsPhone 192.168.10.134 xx:xx:xx:xx:xx:xx Master “Degnan” -82 dBm
LisaIPhone 192.168.10.113 xx:xx:xx:xx:xx:xx Master “Degnan” -75 dBm
Upstairs 192.168.10.103 xx:xx:xx:xx:xx:xx Wired N/A
ZachPhone 10.0.0.102 xx:xx:xx:xx:xx:xx Master
“Degnan_Kids” -79 dBm
Applying changespcWRT TORONTO-N v1.21.1
System Settings
indicates required field.
General
Hostname
Timezone
Choose from all timezones
Choose from timezones with the same UTC offset as browser
America/Chicago
Current Time: Sun Jun 26 09:09:23 2016
Sync Time with Browser
NTP Servers
Enable local server
0.openwrt.pool.ntp.org
1.openwrt.pool.ntp.org
2.openwrt.pool.ntp.org
3.openwrt.pool.ntp.org
NTP Server hostname
Save
Administration
Change Router Password
Enable SSH
Allow SSH login with password
SSH Keys
Save
Hosts
You can add host name to IP address mapping here. One entry per line.
127.0.0.1 localhost
Save
Backup/Restore Settings
Restore Factory Default Backup Restore Backup
Flash New Firmware
Auto update Manual update
Click the “Check for Updates” button to start firmware update.
Check for Updates
Enter your email address below and click “Save” to get email notification when new firmware is available.
Email Address
d********[email protected]
Save
Got your email, thanks! We’ll get back to you ASAP.
BTW, to protect your privacy, I masked your email address, MAC and IP addresses above.
Phew! Thanks for doing that. I didn’t even think of that. I tried doing a full factory reset of the pcWRT tonight, twice, and it has not reset. I held down for more than 10 seconds… but… it still remembers my SSID and also the Parental Controls error still pops up. So for now, I reset my Netgear and I’m back to that for the moment. Waiting until I can hear more from you again. Thank you.
